Using DD floor fills with cosmographer
Is this even possible, i am doing a starship and want some nice wooden flooring on board, how the heck can i do this, im pulling my hair out haha.
    You will need to import the DD3 bitmap fills into the Cosmo 3 map, but that's quite simple:
    - Go to Draw > Insert File
    - Navigate to the CC3 program folder and \System\Fill Styles\. Open "DD3 Dungeon Color". Place it in the map
    - Click "Erase", select "Prior" and "Do It. This erases the actual imported entities, but leaves the fill styles in place.
    The DD3 fill styles are now in your map. To create a drawing tool for a wood floor, click the "All Drawing Tools" button and "Advanced". Duplicate one of the Deck tools and set its fill style (under Properties) to the Wood fill you want.
