I need help with a 3D star/globular cluster template for Cosmo
I was wondering if anyone had a had or knew where I could get a Cosmographer 3 template for a star cluster, or globular cluter ?
I want to add some open cluster and globular cluster maps to my Traveler site.
Thanks.
Edit: I made a template... and its awful. I've attached the png to this post. I'll attach the template further down.
I used Ortho and traced over a 3d map I found. It looks awful. Please help.
Thanks.
This method doesn't give much of a 3D look though.
http://forum.profantasy.com/comments.php?DiscussionID=3995&page=1#Item_3
a set of flattened hexes for level A on the star cluster.
a set of flattened hexes for level B on the star cluster.
a set of flattened hexes for level C on the star cluster.
a set of flattened hexes for level D on the star cluster.
a set of flattened hexes for level E on the star cluster.
All on the same template page. Here is a png of the template I've done so far. I'm no artist and I couldn't get Ortho to work for straight horizontal lines.
I probably made my lines too thin in the above. Not sure when I'll complete this, but I'll share it here when I get it done. The template will have 5 sets of flattened hexes. A through E, but if someone could come up with a template for layers A through F I would be grateful.
