John Speed Map Annual is gone?!?
Ok I went to start a new John Speed style city map and as in the Mapping Guide I selcted NEW->City Maps->checked Decide Settings Myself->Clicked Next->No John Speed Style option at all.
I ran CA2007 over in repair and its still not there. Whats going on?
*edit*
Its still not available that way but I can select the template manually but its all messed up. There is some wierd border that takes up half of the map and does not allow you to draw in that half, when I delete it then the border is transparent and not in the forground. I really don't understand whats going on. Could the August 2008 annual John Speed effect this version?
*edit again*
This problem with the background/border is only on the two smallest maps.
*edit*
*edit again*
If you have the standalone John Speed issue of the annual available, as opposed to the complete 2007 Pack, installing that might fix the issue, as might uninstalling and reinstalling the 2007 issue completely (A repair install isn't always good enough). I would also advice you to check if you have problems with any other templates, or if this is limited to just the John Speed annual issue.
If the above doesn't help, you might wish to submit a tech support request to ProFantasy or this issue. Maybe they know what might be going on.
There _are_ some John Speed templates, but starting the empty template and switching between symbol sets, will result in no John Speed Symbol to be found anymore at all...
- The wizard template is misnamed *.fcw instead of *.fct.
Simply locate the file Annual John Speed.fcw in your CC3/Templates/Cities/Wizard/ folder and rename it to Annual John Speed.fct. This will make the style available again from the wizard.
- Also, the two templates with 750' in them have a messed-up map border.
Fix both issues by unzipping this file over your CC3/Templates/Cities/ folder.
BR, Targas
Any time I try any of the draw tool I now get
No Matching Draw Tool
There is no draw tool matching your
selection in the current draw tool style.
I assume that to access this "All Map Drawing Tools" that I must type [DRAWTOOLSP]? It still gives the same message.
"Add Room" and "Add Corridor" work. If I right click on the city menu and select "City Draw Tool" I get the same message. This is only when I run a John Speed Map and only since I unzipped the files Ralf had instructed to do. Doing that did fix the issue of John Speed city option but now I get this new problem.
- Start a new map based on the Annual John Speed template wizard.
- Switch to the CC3 or CD2/CD3 menu
- Click the All Drawing Tools button. That's the one with the crossed tools (4th down, second vertical toolbar)
What happens?
If you get "No matching drawing tool", got to File > Drawing Properties. What does "Style" list there?
There is a "John Speed City(2)" when you select the drop down box from File > Drawing Properties
Then everything works fine.
Thanks Ralf!
Actually looking into it every Annual (2007 & 2008) now has two versions. Normal and one with (2) at the end.
Does it have a folder called "John Speed City"? Does it have files in it?
If not, it (and the drawing tools with it) went missing at some point. Try re-running the Annual install for that month (or a repair install if you've got the whole thing in one piece).
None of the ones without the (2) have files in it. Should I just delete those folders and rename the ones with the (2)??
In mine the extra folders were called Issue 01, 03, 05, 06, 07, 09, 10, 11, and 12
Those folders were empty and each one also had a duplicate file with (2) after it that had the actual files in it.
Also I'd like to note folders 05 and 11 have folders in them which are also named with a (2) after it. I went and renamed those as well.
