Symbols vanish after placement or on zoom out
I have notice and I cannot figure out why, but in CC3 I draw a map, then I start playing symbol furniture/item's and if I zoom out or redraw they vanish. If I remove the map piece I find them. I have tried to bring to front, push behind nothing works. ANy idea on what I need to do to fix this?
Thanks
    On what sheet war those symbols? It sounds like you're placing them on a sheet behind some other objects that hide them on a redraw.
    As you are placing such a symbol look at the sheet indicator on the top right (S: Name of Sheet). Open the Sheets and Effects dialog and move this sheet down in the list. Does that make the symbols appear again?
