Mulitpoly Not Filling
I'm trying to multipoly a continent in order to fill it with a bitmap, but it's not acting right
Whether I use "Solid" or "Bitmap" fill style, the multipoly either disappears (if I don't check the "Outlined" box) or is unfilled (if I make it "Outlined). I don't see any extraneous lines or odd protrusions from my poly that are usually there if it's leaky.
I figure I'm missing something simple, but for the life of me I can't figure it out . . .
But (as far as I understand), when the line wdth is anything but zero, it s basically filling the line.
Set line witd to zero (like JimP said) and you should be fine.
