Default install llocation
Hi all,
I need to find out what the default install location is for CC3.
The issue I've run into is that some (most) of the addons I purchased don't ask you where you put it. If it isn't where it's expected to be, the install aborts. Very irksome, that. I'd LIKE to get my program installed and running with all the addons, but they can't find the program, and the install script - I uninstalled, reinstalled, uninstalled, REBOOTED, and reinstalled - still remembers the old location I gave it rather than letting me tell it to use the default.
Thanks,
~Ravensun
Thanks,
~Ravensun
In any case, the default location for CC3 is
%ProgramFiles%\ProFantasy\CC3, where%ProgramFiles%points to your Program Files directory (That would normally beC:\Program Filesunder an English version of Windows)I don't recommend installing outside of the Program Files folder for two main reasons:
1. You're subverting the natural malware defences built into Windows by creating a potential (unlikely, but still POSSIBLE) entrance for viruses into your system.
2. Things become unorganized when you've got a million folders in your root (C:\ or whatever drive you install on), and while this is more of a personal issue, it also makes support more difficult later on.
