FT3 will not import MDR.
This is a question for Joe.
I've followed the directions for importing an MDR from Wilbur into FT as outlined in your "there and back again" tutorial http://www.ridgenet.net/~jslayton/ThereandBackAgain/index.html
The same MDR will import into FT Pro with no issue however using the same settings FT3 just creates a blank map. Am I missing something, is FT3 no longer compatible with MDR files created in Wilbur? I have the most recent versions of Wilbur and FT3 and the most recent version of FT3's predecessor FT Pro.
What FT3 version are you running (use Help>>About to get the number)?
I'm following the "there and back again instructions" to the letter and it still works with FT pro so perhaps the patch will fix it with FT3. I will post again tomorrow if it does not work.
If the problem persists, contact tech support and they should be able to get you an update that resolves the issue.
