Reinstall
I own almost everything PF has done (not WWII stuff), and my computer has crashed. I'm waiting on my new computer to get here. Prior to the 3 generation software, there was a recommended install order. I know that is no longer necessary, but is there a better way to do it? For example, what about the art upgrades? If I have the newer 3 version, do I need to install art upgrades? Also, on the symbol sets, it seems like there was an ooley there as well.
--Dale--
    When installing CC3 add-ons, for each addon, install either the Compatibility upgrade, OR the version 3 add-on, not both, as the version 3 add-on contains everything.
    A note about the Art Upgrades though. The art upgrade and version 3 addon is the same thing, there never was a separate "art upgrade" installer. For each addon, there are two options, either the "Compatibility Update", or the full version 3 version of the addon. And as mentioned above, you should only install one of these, depending what you have.
    Remember to install the CC3 v3.20 patch after installing everything else.
  • Thanks for the reply.
    --Dale--
