Restricted Textlength in "Text along a curve"-Tool
 Robak
                Newcomer
Robak
                Newcomer
                    Why does the "Text along a curve"-tool just works for a short text?
I planed to have a text surrounding the whole map in a big circle.
But it doesn't works because the input is limited onto ~ 11 Words.
With best regards
Robak
With best regards
Robak
Better text handling (proper spacing of curved text, leaving it editable as a complete entity, better support of multi-line text), has been on my wish list for a while.
And if you later decide to change a name in the text from "Karl" to "Karl Theodor Maria Nikolaus Johann Jacob Philipp Franz Joseph Sylvester Freiherr von und zu Guttenberg" you have to redo everything instead of useing the same curve a second time just with a longer text.
I regret that text along a line does not work for longer texts
With best regards
Robak
I too have issues with it, since I like to put coordinate markings along the borders of my maps, ie 0-9 along the short dimension and letters along the long dimension separated by the | symbol. It typically takes me 3 or 4 tries to get the visual appearance correct for the 1st/last letter placement. One of these days I'll get smart enough to create a standard border rather than doing it from scratch for each map.
