change the width of a wall
is it possible to do this? i have some 1' walls and want to increase the width slightly. reason being i increased the scale of my windows slightly, causing the edges of the windows to protrude slightly. source included...
Note that since the edge of the wall and the edge of the floor is likely to be in the same location, it can be easier to select just the wall if you hide the sheets/layers for these first.
