Fractal 3 Scale Change of Continent
Is there a way to take a continent within FT3 and scale it down a few sizes and put it back into FT3 map smaller?
  • Yes. Just selc it and resize using ctrl.
    Posted By: Mateus090985Yes. Just selc it and resize using ctrl.
    Ehm... that won't work in FT3, only in CC3.
    You can't rescale part of a world in FT3, you'll have to export it into CC3 and do it there. Getting the whole thing back into FT3 will be very tricky.
    What I would suggest is to select the area of the continent in FT3 with the "Select Polygon" tool, then use Tool > Global Lower > Land Offset. This will lower the selected area and submerge part of the continent below the water level, effectively that will decrease its size.
  • Posted By: Ralf
    Sorry.... I misread it. I did not noticed that he wanted to do it on FT3.
