Small map, Jon Roberts style
After seeing the map from EREB TARNAK made by Gerard SERRE I knew I wanted to do something simular.
So here it is. In Jon Roberts style.
yeah....wow....gonna have to try that....very impressive....wow, etc.
1) The trees are to big, you have to resize them to 50% at least. Also, some trees are bad located (crossing rivers).
2) The bridge is also big. I suggest to resize it.
3) You need some effects on the fields. Maybe a fade inner and transparency?
4) Last would fractalize the rivers.
Good job.
1) Removed the tree in the middel of the river.
2) Bridge is resized.
3) very slight tranparency added to the fields
4) That was the best suggestion. Looks way better now.
Thanks for the tips. First time I used the fractalise command.
Wonderful map! I hope you don't mind if I steal your idea. I love this!
I'd love to find a better effect or transition for the river and road. The river edges look too stark for me, and the road's fuzziness doesn't fit well with the rest of the style.
Unfortunately, I don't have a good suggestion to try: I've been trying to find a good solution for myself. I'm hoping someone else has an idea.
I do like the way the rivers fade out into the mountains -- it works really well.
Steve
Both now just have an inner glow.
Quite like the way this map turned out.
I took the original effect from the standard Jon Roberts maps. They are at a 1000x800 scale.
This map is 10x10. So had to work on the sheet effects. Another good learning experience.
