Moving previously placed symbols
Hello All,
I'm not sure if I missed something somewhere, but is it possible to move a previously placed symbol? If I place a range of ten mountain symbols and realize that symbol #5 is out of place, can I just select that symbol, or do I have to undo symbols #10 thru #5 and then replace #6 thru #10?
Thanks for the help. I hope I'm just missing something, and it's possible to move individual symbols after the fact.
Tony
  • edited August 2012
    Hi Tony,
    To move a previously placed symbol, click the Move Button image, select an edge of the symbol to be moved, Right Click Do It.
    Select a point on the symbol, then drag to new location.
    Left click to place the symbol.
    Yes, the same way you move anything, that is:
    Click Move, Scale, Rotate
    Select the entities you wish to reshape.
    You can click on the edge of the mountain you want to move, then right click and select Do It.
    As you move the mouse, the entities move to follow. Click to place the entities in their new position.
    There is also a Quick Move I find quite useful:
    Press CTRL-Q
    Select the edge of the symbol
    Move
    Place
    You can continue selecting and placing.
