WIP: new continent, cannot get a bay in there
I redraw an entire continent, fractalized it... and now I have problems putting bays into it.
Here is a small version of the map. It uses bitmap fills for everything, but I'll upload the cc3 file as a zip in the next post.
I would prefer not redoing the entire thing... if at all possible.
I did think of adding sheets and adding the bays that way. But I'm hoping for a better solution using the editing tools in CC3.
Thanks !
Thanks !
Let me know if either works...be good to know for future reference.
Are you saying that you want to physically modify the existing map to incorporate more - or that the map is somehow too small to indicate all of the existing ones?
I have the new annual issue, but highly unlikely I'll be able to do anything before this weekend.
Hadn't thought of exploding the multipoly. It is highly fractalized. I don't know what effect/bearing that will have on the results.
Is that what you wish ?
Edit. Hmm...
I meant, I was thinking I didn't want to redraw from scratch. Drawing a new version on top, using the old as a guide, simply didn't occur to me.
