  • 13 days later
    A highly detailed map - I like the lettering in particular. Some of the transistions are a little harsh, and you could perhaps put a blur on them to ease this.
  • where do you want i put blur?could you specify?
    thx
    Simon is referring to the edges of the Farmland and the desert terrains (I think). wouldn't use a Blur though, as that would not look with the Bitmap fill. Instead use an Inner Edge Fade effect on the Sheets with these features. Or increase the size of that effect, if it's already on the sheet.
    Use the LIST command (Info > List) to see what sheet a terrain feature is on, then open the sheet and effects dialog (button on the left toolbar) to check for that sheet and its effects.
    That's a really nice map. I hope I can make something that nice some day!
    On a side note, I can't seem to open the larger version of the map. Do I need to have a PhotoBucket account to view it? :-(
    Really nice work!
    ~Dogtag
