CSUAC/SMAC tip - Easy access to symbol catalogs
2»
  • This should go into the important/sticky topics!
    Thanks.
    It is already there though.
    Added a set of SMAC menus to the top post in addition to the CSUAC ones.
  • 6 days later
  • Hello,
    first: Thak you very much for all this work, this is really great.
    But i have a little problem with the SMAC Menus (sorry if tis was already aswered, but i was not able to find a solution for my here):
    I have put the .mnc-files in the menu directory right under the CC3 folder and copied the lines out of the .mnu-master files into the relating CC3 files in the CC3 main directory. The menus are showing up in the City Designer or Dungeon Designer Add-ons. Also the sub-menues are showing up, bute the catalog row on the left is only showing blank spaces. I have checked all the directory positions and think they are all right. What am i doing wrong? If you need more informations, please let me know, thank you!
  • One thing more: I have extracted all the SMAC-.zips in another folder before moving them into their final position. Could this be the reason?
    If it loads a blank catalog, it means that it cannot find the symbol catalog file (*.FSC file) from SMAC. You need to make sure your SMAC files are located in the correct directory. Extracting them to another directory before moving them is not a problem, but you must make sure you haven't accidentally added an extra folder level.
    For example, the "Carpets.FSC" file (the carpets catalog, should be found at:
    \CC3\Symbols\SMAC\Carpets.FSC
    If you are missing a directory, have an extra directory, or simply a mis-spelling, it won't work
    Note that it is critical for the symbols themselves to be correctly placed, or the catalogs won't work, so the path is not just a problem for the menus.
    The city symbols files should be located under \CC3\Symbols\SMAC Cities\*.FSC
  • This was it: Thank you very, very much! There was a misunderstanding for the position of the .fsc's from me, i tought that i just have to put the extracted folder under SYMBOLS. I did not realized that i had to put in just the content of this folder!
    Now it works, great!
  • 2 months later
  • Thanks! This is a tremendous help.
  • 1 year later
  • So, Question. I tried to add another line under this line.
    #708,PERIHOUSE:[Structures]{|CMENU #menu\csuac_structures.mnc;}|CMENU #menu\csuac_structures.mnc;
    But the program would not start, but i found an alternative, and i was able to add the line under the FCW32.MNU file.
    I was just interested in the reason why, since I like to learn more about things like this. Thanks for your time.
    this is the line i was adding so I could have a section for all my img files :P
    #710,CC2ST:[User]{|CMENU #menu\csuac_user.mnc;}|CMENU #menu\csuac_user.mnc;
    Can't see any reason your line would fail. When you inserted it, did you make sure not to leave a blank line above or below it? Blank lines are the most common cause of problems in these files.
