CC3 Exporting in higher res continually crashes
                    I have a small map I've been trying to export as a bmp or png file to do some work in photoshop with. Whenever I try to export in high res (2200 by 3300 at 99% anti alias) it crashes. In fact any export large enough to have some detail for zooming in with is crashing.
I am running windows 7 and have cc3 fully patched.
I have a problem, when making City maps. Maybe someone can help me.
Whenever I want to open a city with a style (for instance John Speed), CC3 crashes after saving the fcw-file: It doesn`t respond any more and the tast must be terminated. When I reopen CC3, it shows the last map opened before and all houses of the style are black instead of white, but can be placed on the non-city map.
What can I do? What is wrong here?
I installed in the following order:
1) CC3 & Update
2) SS1 symbol pack
3) Annuals 2007-2010
4) CD3 & ScreenFix & HighRes Textures
I use a lenovo SL-510 with Win7 32 bit and 4 GB Ram, maybe this is a problem with the graphics card? But strangely I was able start a map, place 5 houses, save and exit. Afterwards I wasn`t able to reload it.
All other maps work great and I`m very happy CC3! A great tool!
Thanks in advance and best regards
EDIT:
After a restart the problem doesn`t appear any more! I hope that it will stay that way
I use the options Quality 75.
Every time I try this Fcw32.exe crashes.
Why does this happen?
With best regards
Robak
He asked my for a 12000x9000 Pixel Map
In principle I can export 2,4,8 or 16 smaller Maps and he can combine them with gimp or photoshop but in principle one of the biggest advantages of CC3 is that maps could be produced with any number of pixels.
My Laptop is less then a year old and has 8 GByte DDR3 Ram and a NVIDIA GeForce GT 540M.
This crash size is the same as for my old Laptop which had much less RAM and a much less power full graphic board
Are there any settings I can change to allow CC3 to export the Map in such a resolution?
With best regards
Robak
Due you plan to exchange the crash through a warning "sorry our program is not able to export maps with a resolution above ... Pixel"?
regards
Robak
There is workaround to get higher resolutions though in that you can print via pdf and save the export as a PNG file. Simon posted how to do this a while back:
