Are you working in a dungeon template? Try to reload the DD3 catalog setting: Right-click the Symbol Style Toggle button, choose "Master Filer settings" and load the "DD3" setting in the appearing dialog.
It worked once until you try to switch the symbol styles. Now it defaults to DD Pro Line (I don't know what that is) and only pops up the Select Catalog Setting window. None of the Buttons will work in the Select Catalog Setting, I click on browse and nothing happens.
