Latest Annual Release (April Edition)
Hi All
Ive just installed the lastest Annual release and ive encountered a problem. Ive downloaded the software with no problems. It seems to install correctly with no problems but it doesnt appear in the menu option when i try to select a new map template. Any ideas ?
Regards....
Regards....
I hope you can find a quick solution
If you navigate to your #Templates\Overland Maps directory, then take all the files starting with "Annual Herwin Wielink" and move these files into the "wizard" subdirectory in the same location, they should appear in the new map wizard as they should.
The PDF for the style says there is a terrain for mountain backgrounds but I don't see it in the Drawing Tools dialog. I have three Contour, Default (Land) tools, but they have no images shown in the dialog and, when used, they appear to be successively lighter shades, rather than the darker shades typically used for mountains.
Are one of those the mountain background, or am I missing something?
Thanks,
~Dogtag
Thanks,
~Dogtag
So. Weird. Anyway, thank you for your advice Ralf. It wasn't necessary this time around but I'll try turning off the "display sample" if I ever run into this issue again.
~Dogtag
