Floorplan Command: Handling Metric
I'm playing around with the FLOORPLAN command (which is a real time saver, by the way), and found it does not handle metric maps gracefully. It appears that the final map is always in feet & inches measures, even when the starting map is metric. So a 20m x 30m building on the original map turns into a 20'x30' building in the detail map. That can be fixed by changing the drawing units without rescaling, but then the wall ends up being 1 meter thick instead of .3 meter thick and symbol fills are bigger than they should be.
All of this can all be fixed with a couple of minutes of work, but it would be nice if the map came out looking right at the start.
Steve
Steve
