DD Pro and CC Pro
I got a new laptop that has Vista on it. I installed all my Profantasy software, but was having a problem with Dungeon Designer 2, so I bought DD Pro and installed it. When I click on the DD2 button in CC2, it says that DD2 has not been installed. What am I doing wrong? I can not use DD Pro and I hope I did not waste my money.
Thank you in advance.
    The old CC2/CC Pro products are not compatible with Vista.
    You might get them to work, if you make sure you do the following:
    1) Always install as administrator (Right click on the setup files, select the "Run as administrator" option for each setup file)
    2) Do NOT install them into the "Program Files" directory tree, use something else, like c:\cc2
    3) Make sure you install the Universal update 8 after installing all the products
    You'll be better off running CC3 on Vista though.
  • Thanks Monsen. I did the Universal update 8 and that solved it. As far as using CC3 & DD3, I do not have the money for that now.
    Thanks again.
