Problem with CC3 and sample annuals
Im a new user to CC3 and recently downloaded the free sample issues of the annuals (Issues 54 and 36B). The first time I opened these in CC3 they worked just fine but now when I go to use them they come out as a solid color. I dont know if i have changed a setting or there is an error somewhere but I could use some advice on fixing this. Thanks
Here are screen shots of what I am seeing
Fill styles are embedded in each template, so you cannot use the "wrong" set of tools in a map. If you wish to use these tools in a regular dungeon map, you must first import the fill styles from a battle tiles template to the dungeon template. When a drawing tool cannot find the correct fill style in a map, it will display in a solid color.
Happy mapping.
