Box command at different angles?
In the Mappa Harnica toolkit there was a command to do boxes at non-right angles. Is there a command in CC3 that does that?
    If you have Dungeon Designer, you can use the ROOM command to do this. Type ROOM at the command line, select the rectangle option, only activate the floor background option and set the color and fill style as you like. You will have to change the layer later, as the room command uses fixed ones for these.
