interesting problem, exporting graphic files
I was exporting a graphic from my 10x10 map to show here. I got only one column, instead of all 10 columns, of the map. I figured it was due to each of the 100 map inserts may have part some of them with the 0,0 on them. Maybe a bit of confusion. So I set origin, and made the lower left corner to 0,0. No change.
I had to export as rectangular section to get all of the map.
The below is what i got first try.
Btw, you seem to be completely missing a proper map border. You should add a simple rectangle to the MAP BORDER layer to form the outline of your map, even if you don't have a fancy graphical border.
As for your bitmap files, it isn't that difficult to troubleshoot a map even with a few red X'es showing, so downloading them isn't necessary for strictly troubleshooting purposes.
Easier fix than I thought it might be.
