DD3 - Wallcutter?
A very nice tool, but it simply doesn't work half the time.
A drew up a nice, large room, and used the wallcutter to remove part of it. That worked fine. But through the last hour, no matter what I've done, it won't do anything to the rest of the walls in the room. Doors don't work either. It's like the program doesn't know there is a wall there anymore.
I'll attach the file. It's the wall between the red brick square and the stare on the inside that has to be removed.
I did find a workaround though. Just use the Split
I'd just delete the room wall and redraw it using the Wall drawing tools.
