Should I uninstall CC2?
I installed CC3, DD3, CD3, and SS2 and, personally, I am having problems with it. It's not doing things the way it should, some elements appear to be corrupted, and I did install the updates. I am beginning to think the fact I have CC2 Pro still installed is the culprit. Should I uninstall it and reinstall all of #3 again to fix the problems?
    It is certainly problematic, if you installed CC2 and CC3 into the same location, but otherwise they shouldn't interfere. If a de- and reinstall doesn't fix the issue I recommend you put in a tech support request.
