Strange Artifacts in Lighted Bezel Function
I'm using the 2024 Watabou Cities revised template, and I'm getting strange artifacts in the lighted bezel effect. I did edit the effect with the following parameters: Bevel Size: 50, Intensity: 20, Smoothing: 2 units. I also changed the original 20% gray fill to the CA211_Grass_Green_Dark fill to better match the background.
I'm getting a weird inconsistent golfball texture. It changes with magnification. If I zoom in very close, the texture overlaps, causing a pretty interesting semi-random 'smooth hilly' effect. How can I eliminate this?
I
That's Transparency Acne. It happens when you use very similar or the same texuture on two different sheets, and the upper one has a Bevel, Bevel, Lighted, Glow or Edge Fade, Inner sheet effect.
There are a number of ways to remedy this.
