Ferraris Hedgerow Bushes change scale
Hello,
Been trying to change the scale on the Ferraris Map, found my way for fills, but could not find a way to change the scale/spacing of the Hedgerow Bushes Tool that spawns bush symbols along the line. How can I change the scale of the spawned symbols so that they are spaced more and bigger?
Thanks!
Claude
Once you have used that drawing tool once the settings file it uses will be the default option if you then use Symbols Along from the Draw menu.
Then you can pick your line and alter the settings for this set of symbols along. Here I have made all the symbols 150% original size and switched off Use Sym Width so I can put 50 (map units) Between Symbols in the Distance pane.
The left line of bushes is the original drawing tool, and the right line of bushes was created using Symbols Along as described.
I love that tool.
Some other cool things you can do with it!
Thanks so much!
Claude
