A first map, "The Mushrooms Lair (Thieves Hideout)"
I once again want to thank everyone for the warm welcome I was given on late November. I had then decided to practice with the software a tiny bit before showing anything, and with the help of watching VODs of several Profantasy livestreams, as well as searching on the forum (which contains a lot of informations), I was able to find the answers for most of my questions.
I finally decided to post a dungeon map that I made, well, today, which was an attempt to use SS2 Bitmap B (I think that's the reference for the style), using most of the knowledge I gathered, such as but not limited to :
- Using/customizing sheet effects
- Understanding how to measure distances and adjust the scalebar text accordingly
- Apply a Pink (for exemple) texture behind the sheets using the Bevel effect to remove the triangular artefacts
- Using the pipette tool to extract properties then use the shape drawing tools to obtain the result I want
It was also my first attempt at trying to make a Staircase that wasn't made out of symbols using the Stairs tool (I understand the 2024 annual, May, has a deeper toolset for this, however I'm trying to keep exploring for now with what the bundle gave me).
It is a vertical map, I don't think I see a "spoiler" feature here to make it so it won't display without user interaction by default, if there is such a feature, or if I did something wrong or something I shouldn't have, feel free to tell me. For convenience, I also made a gallery with this image at a higher resolution.
Have a great day everyone, While I'm not specifically looking to change this map, I'm fine with any feedback you may be able to give regarding issues or things that could be better.
PS : I also want to thank Ralf for answering my queries regarding licensing questions (I didn't send a "thank you" by email as I thought it'd be better to keep the emails for actual queries, so I'm saying thanks here if you happen to pass by).
That's a really good effort, Fishou.
If you were going to make any adjustments to it I recommend changing the background fill to something other than that rather scratchy stone background - not the cave floors but the surround. There are lots of others you can try in that style.
Really great map, and some pretty advanced techniques for a first-shared map -- like making your own stairs and dealing with transparency acne. Nicely done.
