Fireplaces in Interior Colour
Using Harnic Interior Colour in CC3+, the Fireplace symbols do not show the yellow flame in my maps.
As far as I can tell (I have not tried every symbol), all the other symbols display all the colours in the Symbol Catalog.
Thank you in advance for any advice and help.
Is this from the non-ProFantasy Harn Style of CC3+ mapping developed by Roy Denton? I don't actually have this installed, so can't really help, but if it is, I know a few of our longer-standing Forum contributors do, so can hopefully assist.
Do you have the harn.pal file installed in your data directory. That could be the issue with off colors. looking through the docs no where does it state to install that file. I know you need it for the Original hark files and based on the unzipping of the above mentioned version it appears it also needs that file.
Without the harn.pal file installed and active the fire should be red at least mine are. They turn yellow after I load the harn.pal file
Just verified that you need to also load the harn.pal file to see the correct colors in the symbols. you can do is by
copied from google
This method loads the palette for the current session, allowing you to have multiple
.palfiles available.harn.palfile in a convenient location within your CC3+ data directory (e.g., in a newPalettessubfolder). The main data directory is typicallyC:\ProgramData\ProFantasy\CC3Plus\.PALLOADand press Enter.@symbol to refer to the main data directory (e.g.,@Palettes\harn.pal).harn.palfile.You can also rename the FCW32.pal file to something else (org_FCW32.pal) and the rename the harn.pal file to FCW32.pal but if you do this then all the other maps you load that do not use the harn.pal will be off color.
