Problem to install Character Artist 3
Hi,
I need help to install CA3, please.
CC3+ not found whereas I was install it before.
It s the good version of Installer.
Did I forget something?
Hi,
Shut down CC3+ before you do any installing.
Run the CC3+ core app installer again. You should be offered the Repair option. Take that option, then shut down CC3+ and install the latest CC3+ update. Then shut CC3+ down and try installing Character Artist again.
If you still have problems with the installation please contact Tech Support via your registration page. There should be a tab called Support once you have logged in.
