Executables
I recently purchased all of the CC3+ programs and files via an amazing Humble Bundle offer. After downloading a ton of programs and content for CC3+ (virtually everything I had with CC2 and 3 and then some), including the primary program, I noticed that almost every other addon is an executable. My question is, after successfully installing the core program, do I run each of those executables to install them? Not including the primary program executable, there are 42 (!) more to run. Is that how the full catalog of options is installed? I figured I'd better ask first before running all those exe's. Thanks.
Best Answers
Answers
    Accepted Answer
    Yes, that's right.
    Install the core app first, then the latest update, then all the add ons and annuals, then run the latest update again right at the end.
    FT is a separate app. You can install that anytime you please.
    VarlRoyal ScribeRyan Thomas
  • Followup: I noticed while installing all these executables that some of the addons have two executables with in a folder. One for CC3Plus and one generic (?) For example, the Symbol Set-Fantasy Overland folder has SS1SetupforCC3Plus as well as SS1Setup. Do I run both? The CC3Plus one installs just fine, but I wasn't sure if I even needed to execute the other. This question applies to all addon folders with this configuration. Thanks!
    Accepted Answer
    You only need the one for CC3Plus. Other executables are for older versions of CC that are no longer sold, but which some of us old timers still run every now and then.
    Varl
