Fractal Terrains 2.4?
I was wathing the FT tutorial videos on You Tube and in one of the videos you see a "Layers" page in the export filter.
One the comments about the video asked about this and the reply was that video was made with version 2.4.
Where can I download a patch or something to upgrade to 2.4? My version just reads as 2.3
The video I was wathing is at this link if your not familar with the one I'm refering to.
Thanks
Thanks
FT Pro 2.4 is in beta test right now as far as I know - I assume that it should be out shortly once a few minor bugs are ironed out.
I started playing with FT Pro again and looking at what was on the web for it after seeing your great stuff.
I am trying to export the world map to CC3, I have watched all the tutorials I can, but they all seem very outdated. Mostly done years ago, what I want to find out is which file type setting should I use.
Most of the videos use something called Europe export, there is no Europe export anymore, so what is the best one to export the world too?
It is one game I would love to play in person, on an actual table.
http://www.farfuture.net/
Also what is the best map type to export the whole world (multilevel) to fantasy grounds, ie: mercator, miller cylindrical ect.
That aside, I don't really recommend using the multiple file exports. It creates a bunch of maps divided up around an artificial grid, often ended up with a division straight down central places. Instead, I recommend doing as we do with the community atlas, exporting the top level map, and then pick regions of appropriate size to make detail maps from, without limiting ourselves to a specific chunk size. these regions can either be mapped by extracting the contours from the parent map, or by zooming in on that location in FT and do a new export of that particular area.
