Selecting multiple entities using entity tags
Hi there - is it possible to select multiple entities using entity tags. For example, I have about 50 entities (various tree symbols) with entity tags in a sequence from 22831 to 22881. These symbols are amongst other entities that are on the same layer, sheet, have the same entity type etc and therefore the tag is the only way to distinguish them. I was hoping that when it asks for the entity tag I could write something like 22831-22881? Any help would be greatly appreciated.
Unfortunately, it doesn't support ranges.
Maybe doing selections by name instead will help? (It's a bit down the page in the article)
Hi Monsen
Many thanks for your response - I think that will do it! Couldn't see how to do name but now understand as it is part of the command line syntax.
