Copy to another map
I want to take a bunch of smaller decks for a Cosmo ship plan I'm working on and copy them to a single file showing mulitple decks. If I copy and then paste the details from one map to another, it seems to want to move EVERYthing copied on to the same sheet instead of retaining the original sheets of the source map. Am I doing something wrong, or is that inherit in the copy/paste function?
As an alternative, you can also use Draw -> Insert file and insert the entire map into your current map, then delete the entities you do not need. This should also preserve sheet information.
Set the current sheet to Common on the source? or the Destination?
