Changing the room placement crosshair color
When placing a new room on a map there is a black crosshair that shows you where the room will be drawn at. On maps with a dark background this black crosshair is hard to see.
Is there a way to change the color of the crosshair from black to some other color?
I don't think there is.
Can you hide the dark background to draw the room?
The crosshair isn't actually a color. It is drawn as the negative color (XOR) for anything it is over, so when over a dark background, it is light, and over a light background it is dark.
I am using a medium to dark gray texture for the background but the crosshair is black. Hiding the background fixes the problem but that is an extra step I was trying to eliminate.
