Best Way To Uninstall
 KertDawg
                Administrator, ProFantasy 🖼️ 4 images Surveyor
KertDawg
            What is the best way to completely uninstall CC3+?
I have a Surface Pro 8 that I use CC3+ on sporadically. It's worked 95% of the time. I had a problem with Fantasy Realms Reimagined where the installer would quietly exit before installing anything. I worked through that with tech support, but it involved special versions of that one installer. I'm having the same trouble with this month's CA. So, I decided to reinstall CC3+. I'd like to clean up first. I can't find anything on the forums for recommendations on how to COMPLETELY uninstall CC3+, including settings, cache, etc. I wonder if anyone can point me in the right direction. Is a simple point-and-click uninstall enough?
Thanks for any conversation on this.
I recommend contacting Tech Support if you have any doubts about a simple uninstall being adequate for what you want to do. You can do that using the form at the bottom of the "Support" tab on your registration page when you log into your account on the main webpage.
Thanks! I appreciate the advice!
