Community Atlas - Forlorn archipelago - The Bleakness, 2 villages and 2 keeps
2
    I talked myself into making an under water, eastern most underground lake, area. The plain bitmap fill works for land, but it should be rougher under the water. And there are no isometric rocks.
    about 500' x 400'
    I may just do this as an overhead view...
    Any suggestions to fix this up as an isometric map ?
    Royal ScribeRicko
    Tossed in some rocks from Marine dungeon, I just put them on Symbols, no other effects.
    LoopysueRicko
    Well, in an attempt to fix some problems in playing Everquest 2, I was informed my graphics chip is better than my video card.
    Resolution is 1920 x 1200 instead of 1920 x 1080. Only 128 megs video ram though, instead of gigabytes of video ram.
    But it might be easier for me to see my maps.
    Those rocks you put in that last map have a magenta Color Key patch underneath them that is designed to cut a hole in one of the water sheets in Marine dungeon. The pink polygons are showing in your map because they don't have any effects. You might want to delete them, or the sheet they are on if you aren't using it.
    I was thinking about adding those sheets in, but various problems took up my time.
    Hopefully I'll do that this week.
    I did the copy and paste from one fcw to the one I'm working on, and here it is. I think I got it.
    Preliminary of course.
    Tired and logging out for the day.
    LoopysueRicko
    Update, all of it, then close-ups
    Water Town
    upper left
    upper right
    Ricko
    central buildings
    lower left
    Some parts of this map are done, other parts are preliminary
    More kelp, more deep rocks, more sharks, etc.
    LoopysueRickoMonsenQuenten
    edited February 2024
    update, upper left but no zoom in. The new building in the center rock is the court room.
    Yes, there are torches and wooden chairs. Think of them more like magic of some sort on the torches, or maybe those old magnesium flares that scuba divers used years ago. As for the wooden table, chairs, and throne, maybe a wood that lasts underwater, like cedar.
    Shutting my computer off, big thunderstorm heading into my area. Could lose power.
    Royal ScribeMonsenLoopysueRicko
    Storm gone for now, but another on its way.
    There are two large water caves for this area...
    I would love to have more rocky island areas in the second underwater city/town. Instead of the flat areas as shown on the above maps. A bumpier surface. The map above is must too smooth.
    Any suggestions on how to do that ?
    Thanks muchly.
    Try a fill with a more visible texture. It gets a bit harder to find something nice due to the perspective nature of the map, but you could try with something like the Stone Lava Cooled bitmap from DD3.
    Additionally, the pixelation of your current fill is really bad, causing it to appear more like a uniform mess. Try decreasing the scaling of the fill as well. That leads to more repetition when zoomed out of course, so you may need to consider working a bit with the surface, applying layers of different fills and blending them using effects to avoid the repetition.
    Thanks. Kinda busy today. I'll try that later on.
    I tried several scale settings for the current bitmap fill, but couldn't get it to look good. I'll keep trying.
    I plan another underwater area, deeper down. I'll have to look over the maps and decide from there nothing decided just yet.
    edited March 2024
    It looked too dark, so I used a different one. Castlewall_LtBrown_blu_kpl
    overall map, and a 5 k pixel one in my JimP's Gallery -> larger Atlas maps
    Note the kelp looks like there is a water flow. Those submerged rocks on the bottom of the map look a bit slippery.
    I'm not sure how to add a compass rose to this map and scale so they look correct.
    dorm area furthest from the viewer. The ceiling is covered. Cut-away so you can see detail.
    I added some rocks from Sue's newest Annual.
    dorm area closer to the viewer, same deal, it has a roof, but cut-away so you can see detail.
    MonsenLoopysueRickoRoyal Scribe
    Preliminary map for Water Town, lower. An area of crime, and danger.
    Note the algae covered rocks. No giant snail wranglers will come down here to clean the algae off the rocks. And notice the cloudy water.
    You've never heard of them ? Well, since I just made them up, I'm not surprised. Need some giant snail symbols that are Isometric and Atlas ready...
    Local rules for both water towns, no swimming over a building. Must use entrances and walkways.
    LoopysueRicko
    This could get lots of maps; however, I am leaning towards doing what I did previously. Using strip maps to connect the water areas to the surface.
    edited March 2024
    Needs fixing up, but I've added two symbols from City Ruins CA138. 5k in my gallery. And a transparent water over the entire map.
    I thought of this during the mapping session today.
    Royal ScribeLoopysueRicko
    Updated Lower Town, buildings named. Jail and Arena.
    The small bit down here has treasure. The floor piece by itself, wobbles. I'll be adding sharks nearby. Why don't they attack the inhabitants ? They have been tamed, and learned its a bad idea.
    Royal ScribeRickoLoopysueMonsen
    Another Lower Town update. Added a Big Shark in the lower right. You could call it, The Big Kahuna Shark. Just to the left and slightly up of the text, is a treasure out in the water. Sharks guard it.
    Added more marine rocks, kelp, coral, a few schools of fish, etc.
    Still thinking about what other buildings I can place on these water town maps. Probably need to add rocks and kelp where the Big Shark is located.
    LoopysueRoyal ScribeRicko
    A bit of an update to Water Town, Upper. The connection to Water Town, Lower is in the lower left corner of Upper Town.
    I'm not making a tunnel connecting them, unless requested.
    Royal ScribeLoopysueRickoMonsen
    edited March 2024
    This is a current list of maps and map names, along with projected maps.
    If you see a bad wording, etc. please let me know.
    the earlier map versions are up thread.
    Burnt Pillar Area
    burnt_pillar_area.fcw
    Guard keep
    guard_keep.fcw
    guard_keep_basement.fcw
    Red Out keep
    red_out_keep.fcw
    red_out_keep_basement.fcw
    Unforgiven keep
    unforgiven_keep.fcw
    unforgiven_keep_basement.fcw
    Bastion keep
    bastion_keep.fcw
    bastion_keep_basement.fcw
    Burned keep
    burned.fcw
    Deep Side View
    deep_side_view.fcw
    Water Town Lower
    water_town_lower.fcw
    Water Town Upper
    water_town_upper.fcw
    Deep overhead view
    deep_under_burnt_pillar.fcw
    tunnel stairs under keeps
    stairs_a.fcw   under Burnt Pillar
    stairs_b.fcw   under Scorch keep
    stairs_c_fcw   under Burned keep
    scorched_keep.fcw Scorched keep
    lost_village.fcw Lost village
    not started yet
    Scorch keep
    Burned village
    And 2 strip maps connecting the water areas to the long tunnel. 23 maps.
  • 10 days later
    Scorched keep, with a pit door for going down into the tunnels below.
    Is this a bit busy ?
    QuentenLoopysue
    Hmmm... I don't see a Scorched village, so that is off the list.
    Lost, a village. A small 15' x 21' square of logs... two unlit campfires, and a backpack. A camp fire in the lower left, Southwest, ruined keep... too obvious. Cracks in the ground. Do they lead some where ?
    I think I might put some of these maps on Crestar, in The Great Erg, a very large desert area.
    I'm going to a cardiologist on Tuesday April 2, to see if I have a heart murmur or not.
    I'll let you know.
  • Hope all will turn out well, Jim, thinking of you.
    Oh no! I hope everything will be ok.
    Good luck Jim. Hopefully all will be fine.
    Good luck! Sending love...
  • Good luck, and all the very best Jim!
