City Designer's Index creates angled text
I'm following the essentials tutorial for CD3. When I create an index, the text of the index comes out at a 30 degree angle, both the label and the coordinates.
The hyperlinks of the index work. How do I straighten out the text? I tried using the arrow keys before placement, and rotating the index.
Best Answer
Loopysue ProFantasy 🖼️ 41 images Cartographer
You could edit them using Change Text Properties in the Edit Properties
right click menu, but it might be faster to recreate the index after first checking that the angle of the text is set to zero in the Text Specs setup.
Answers
setup.
That's what I missed-- putting text on a road changed the angle in Text Specs. Thanks!
You're welcome :)
