Smart way to export a sheet
Hi,
I made a large scale map and now, I would like to zoom on regions.
Is there a way to do it better than:
- saving to new file;
- purging all sheets but border;
- scaling border line ?
OR:
- export borders as image;
- import image;
- traced it ?
Best Answer
Monsen
Administrator 🖼️ 82 images Cartographer
You can create a new map the normal way, and then just use clipboard copy to copy over the entities you want, and then trimming away the parts you don't need with tools like /.
Lots of information here:
Ralf also did a live stream:
Answers
You can create a new map the normal way, and then just use clipboard copy to copy over the entities you want, and then trimming away the parts you don't need with tools like Break
/Split
thanks !
