Create new Symbol Catalogue
 brandor
                Traveler
brandor
                Traveler
            Hello everybody,
I have a spontaneous question: when I create a new symbol catalogue via the wizard, I am asked to save the map(!) at the end of the wizard and the save dialogue (Save your new map) appears. I can only select the map (FCW) as the file type. But I want to save a catalogue, don't I? Sure, I can then save the whole thing again as an FSC type via "Save As...". But why do I still need the whole thing as a map? Is this intermediate step necessary?
Do any of you have any tips / information?
Thanks
Brandor
It is a limitation of the Wizard. If you use the pre-defined template option instead of decide settings myself, you can just pick the symbol catalog template and it will use it without you requiring to save the file as a fcw first.
When you hit save from the first time then, you can pick the symbol catalog type directly.
Ok, I can live with that :) Thank you very much for this information.
