Cosmographer Issues
So I just got Cosmographer and I'm designing a ship based on what the booklet tells you. I build the hull and it looks great and then I get to page 6 of the booklet where it says in the first part:
18. Pick a deck to work on from the indicator at the bottom of the map.
I've looked all over and I can't find the selection to allow me to go up or down decks. I'm considering cutting my losses and forgetting the outer hull and drawing two copies of my deckplan side by side to make things easier. Anyways I just wanted to see if anyone could direct me to the interface where I can switch levels, so far I have no idea how to find that.
    There should be a list there:
    Deck 1 2 3
    Clicking on the number will change to a different map.
  • Here is a picture of my screen, I honestly can't find it, I'm sorry.
    edited August 2010
    I believe this feature was somewhat changed from the original Cosmographer way because of the introduction of sheet effects (Cosmographer originally used one sheet per deck). To have multiple deck levels available, you need to indicate how many you need in the new map wizard (final step). When you create a map with multiple levels this way, you will get the appropriate indicator at the bottom right of the map.
    Note that it now uses one map file per deck instead of one sheet before.
    And for the future, please use a paint program to crop your screenshots. You have a huge unnecessary white border to the right and below the actual screenshot.
  • Posted By: MonsenI believe this feature was somewhat changed from the original Cosmographer way because of the introduction of sheet effects (Cosmographer originally used one sheet per deck). To have multiple deck levels available, you need to indicate how many you need in the new map wizard (final step). When you create a map with multiple levels this way, you will get the appropriate indicator at the bottom right of the map.
    Thanks that makes sence. Lol yah I didn't realize the big white chunck was there untill after I posted the pic, I'll crop next time.
