Is there a way to search all Symbols across catalogs?
Frosty
🖼️ 22 images Surveyor
For example if I am looking for display cases to outfit a basement that has been turned into a museum is there a way to search for display case or weapon rack.
Click the open symbol catalogue button at the top of the symbol panel. Navigate to the Symbols folder and use the Explorer search bar to search for words like cupboard, or rack. You will get everything from every style you own 4 times over for each symbol because there are 4 different resolution images for each symbol. Give the search a chance to look in all the subfolders. For some reason it seems to stop after the first thing it finds and then after a few seconds it shows the rest of the results.
If you find something you want in the results right click it and pick 'Open file location' and go up one level to pick the catalogue file - the .FSC file. It will have the same name as the folder you were just in. That will open the right catalogue for the symbol you want.
So simple never crossed my mind.. instead I been browsing through symbol catalogs when looking for something.
Someone else had to explain it to me a couple of years ago, so don't worry.
I hope you find what you want.
Duh. Thanks!
Request for version X....
Please make all of this an internal process... ;-)
