How to make the line of "default cave" darker and wider
How can I make the "cave, default" in the tool to be more wider and darker.
I only managed to make the wall get wider but it went over the edge.
The reason it doesn't show so large is because the map is so large itself.
Can you show us a screen shot?
Ok, thanks.
If you want to make the wall thicker, hide all the other sheets and use Change Properties on the wall alone, giving it a wider line width.
If you want to make the sheet effects more prominent (the glows and shadows), you can edit each effect singly to give them larger widths or blurs. To do that, open the Sheets and Effects dialoge and pick the sheet, then pick the effect you want to edit, and click the EDIT button on the right next to the effects panel.
