How to set symbols under other symbols
How can I set symbols under other symbols so that I dont have to do it complicatedly.
Like, deleting symbol and putting it again over the symbol which I wanted it to go under.
It may be very frustrating or time taking otherwise.
On the right side of the software, you will see squares. Some under and some over each other.
Use bring to front, to bring the one you want on top to the top. That one is on the upper left of the 4 of these.
Have you tried Sort Symbols in map?
Sort Symbols? No I havent.
But I know now how to bring the symbols to up.
Sort Symbols is commonly used in overland maps, where it is preferable for all the symbols to be arranged as a cascade from top to bottom - with those at the top of the map being the symbols at the back, and those at the bottom of the map being in front.
