moving items using command line, starting from top right
I use the command line a lot more than most people because my dexterity is awful.
Instead of starting more or less in the middle of the drawing area, I started in the top right. I know how to move stuff just with the command line, but this only seems to work from 0,0 [bottom left] up and or left across the map. Is there a way to work in the negative, [e.g move from 664,44 downwards to 7o,44]? I tried moving it with negative numbers but CC33+ told me it didnt know what I was trying to do.
