Bevel question
Ricko
🖼️ 106 images Mapmaker
Is there any way to place a Bevel effect but in a "negative" way in order to simulate the depth of a Chasm? I'm currently working with 13th Age.
Thank you very much
Here is a pit I made, fcw is in my post there.
If you're using the "Bevel, Lighted" effect, there is a control to turn off the global sun and pick your illumination direction for it. Theoretically, turning the light from the opposite direction for a few sheets will get you the illusion of things pointing downward rather than upward. There is no such illumination direction control on the regular "Bevel" effect.
