Symbol Fill: Symbol name always crashes
Ratty
🖼️ 4 images Traveler
Hi,
How do I use the symbol fill here?
Every time I choose a symbol from the 'symbol name' field, CC3 crashes. Most of the fill styles seem to be either small circles (pictures) or completely blank.
To start with the basics, you're probably not wanting to use the Symbol fill at all. It is a very ancient way of filling with symbols, and only gives a very regular pattern. You're probably want to use Draw -> Symbols in Area instead.
Not sure about the crashing, but I am able to reproduce it, so I'll bring it to the attention of the developer. But this fill type is likely to go away in the future, so a fix is likely to be lower priority.
Ok, thanks. I'm mostly glad I haven't borked something in the install!
