Lines
Is it possible to have the program draw a line from my selected point to a predetermined distance and bearing ? I am mapping a real world camp site and have a rough sketch of the area with trees marked and measured out. I used an iPhone compass to show me the bearings. Hoping to use this to map out the grounds to have a preset idea of where some thing should be placed.
Thank you
Darren Mc
Sure, after placing the first point, type in the second point on the command line as <45,30 where the first part after the comma is the bearing, the second is the distance.
Keep in mind that the bearing is based on CC3+'s coordinate system (your standard mathematical coordinate system) and not compass directions, so 0 is right (east), 90 is up (north), 180 is left (west) and 270 is down (south).
You'll find more about coordinates here.
Thank you so much !
I will adjust the bearing and map away ;-)
