Is there an easy way to tell which light is which?
Ratty
🖼️ 4 images Traveler
When editing lights, if you press the 'edit lights' button, you get a long list of all your lights and their coordinates. You then click on the correct light from the list to edit it.
Is there an easier way to edit a light? (Rather than have to check the coordinates of each?)
Thanks!
Use the Numeric Edit
command on the lights directly in the map (visualized by a cross in the light's color)
Ah, thanks so much!
I'm going to stop asking questions and try to get the map actually made now. I'm having fun, even if it is very new to me!
